Bengt Backhaus
Edited to delete because i was misinformed by the supplier
				We bought it used and didn't get anything like that.It's just machine oil. Use whatever you like.
Klübersynth DB 2-68
Klübersynth DB 2 oils are synthetic lubricants based on a mixture of ester oil and synthetic hydrocarbons. They are intended for use in both low and high-temperature applications. Silicone is not used in the formulation of the products. With their additives and their particular composition...www.klueber.com
Even the small hp bottle should last a lifetime if you are not overusing it. And you always get a new (2) one from Smk3 service.
The lubricating felts are presoaked with oil. 3 in 1 is perfect.So a 3-in-1 oil will work for this then?
Also, related question: when swapping out the lubricating felts do they go in dry?
How much oil did you place in the resevoir?
