Onyx 21 True Black help
jason91
I need help in onyx getting my greys and blacks to print true black channel only... I created swatches from 100% K down to 10% K...When I print it has a mix of cmyk in them....
I selected In the Color Management Icc Pure hues box black only, but its didnt change anything, its still mixing my blacks...Help please...
Pauly
Printrade.com.au
Colour replacement tool in job editor you can define a colour with the ink channels.
Pauly
Printrade.com.au
what about when I bring in a true black grey gradient? Is there a certain profile that would change it to true black?
You can turn ICC profiles to "off" and that will print the files CMYK values.
I wouldn't be doing this for all job or jobs with colour, but it's the way i'd print a K only gradient.
jason91
i tired changing the advanced black generation to primary black only now onyx crashes every time i try to rip something???
Saturn
Your Ad Here!
I have not played with it or tried it myself—but in the Edit Quick Set menu window under Change Profiles... you can click a button to the right of the profiles called Setup Pure Colors that takes you to a ICC Pure Hues window. Within the ICC Pure Hues window you can click on Black or Black/Grey, and the info/details seem to indicate it will do what you want, i.e, leaving your pure K 100% black versus making it rich.
Onyx - GamaPrint 19
Saturn
Your Ad Here!
Just tried it and can confirm it works. Obviously you need to understand how to generate 100% K text and raster images first too. I used to do this all the time in InDesign for thing going to more traditional printers, but wasn't sure it would work quite as easily in Illustrator, even worked with the document color mode set to RGB. Definitely something I would trial-and-error check first—for critical work—as things aren't always obvious working with greyscale in Illustrator.
Pauly
Printrade.com.au
i dont know what you've done.
Change the ICC profile in job editor to "OFF"
View my screenshot.
Also i think Saturns method will work.
It depends on what you're doing.
Saturn
Your Ad Here!
Jason, sorry, just saw that you were already trying the Pure Hues menu. Duh! What program are you creating your artwork in? I've tried it a few times now, and Pure Hues works great for me, but I still would have to test it to be sure of things, as it still really needs to be grayscale, not just "black" or desaturated. Depending on the software it can be difficult to tell what's what, when it comes to blacks. I only know Adobe stuff.
Wish I could offer more help!
