Onyx doesn't see network drives
Mega-Tech
So we ended up buying Onyx Postershop, got it all setup and tested it with some files on the desktop. We got busy and kept using Flexi until it slowed down a bit.
One issue I ran into right away is that Onyx won't see any mapped network drives. The only way I can rip is if I copy the file to my local computer.
What program in this modern age doesn't see network drives?! Anyone run into this issue and found a workaround?
Thank you!
SignMeUpGraphics
Super Active Member
  1. In Registry Editor, locate and then click the following registry subkey:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
  2. Right-click Configuration, click New, and then click DWORD (32-bit) Value.
  3. Name the new registry entry as EnableLinkedConnections.
  4. Double-click the EnableLinkedConnections registry entry.
  5. In the Edit DWORD Value dialog box, type 1 in the Value data field, and then click OK.
  6. Exit Registry Editor, and then restart the computer.
I think this is what fixed it for us.
Reactions: 1 users
Bly
I think I had that issue when running the app as administrator.
If you're doing that try just running as a user.
Mega-Tech
Much appreciated! That worked perfectly!
twister
Worked for me as well with Onyx21 Postershop when upgrading from version 12. I could see the network fine with old version but after upgrade I lost the mapped drive. The registry edit above fixed the issue.
StikiBiz
Thank you!
Have you got Onyx running as Administrator? That could be your problem
