OPOS Paneling
Kate
Hi All,
I have a continuous graphic that is 180" wide x 41" tall and was thinking about using the OPOS paneling option. I have never used either the paneling or OPOS paneling before.
I believe I read that the Summa doesn't like to cut files longer than 13'. Does that statement also ring true when using the paneling option? or should I just cut the file in half and have a seam in the graphic?
The graphics will be printed on 3M 180 using an Epson SureColor S80600.
The graphics will be cut on a Summa S2 T140.
Thanks in advance.
pkeshtgani
Hi Kate,
On Summa panel you would want to turn on OPOS Paneling (4 Marks). There is not changes on your end in terms of printing. When you start by reading the first mark, it would one mark down, moves over to left side and read the two marks and than start cutting in panels. This method will increase accuracy.
Hope that helps!
