Orajet 3651Intermediate Calendared - Ok W/Rapid Tac
gemhdsigns
Hi!
Question: Have a large 60” Diameter backlit install which we’re using Orajet 3651 (not 3651RA). It’s been a challenge eliminating bubbles on this large install - having to reprint.
Any issues / concerns with using Rapid Tac with this media?
I typically stick with dry installs but I feel like with this material, and this size print, it might be best to install wet.
Would welcome thoughts
Thank you!!
jcskikus
Owner, Designer & Installer
Use RapidTac lightly. Test it with a smaller piece on the surface you'll be applying to. If it gets too wet, it's best to make sure all bubbles are out and either let dry time or use a heat gun to speed the adhesion process. You using 210 or 290 as overlaminate?
gemhdsigns
Thank you.. Using 210 for laminate.
