Orange and Green swatches for Coreldraw?
landdesigns
Where do i Find Orange and Green swatches for Corel draw in Versa works 7 ... searched and can not find.
[C:\Program Files\VersaWorks\Swatch\CorelDRAW or userinks.cpl, cant not find?
Thank you
It's located in the Versaworks 7 Category where you can download Versaworks. I was just snoopin' around.
Oh, awesome. I found it. thx. Yeah, it is only under VW7 not VW6. I am still installing VW6 as much as possible. But good to know where the swathes are. Also they are located in the Program Files VW folder, Swatches.
searched several times no swatches
You have to import the .cpl and .xml files into Corel and they you will see the Roland swatches
How to Access Roland Swatches in CorelDRAW
To enable the built-in Roland color palettes, follow these steps:
  1. Open the Palettes Docker: Go to Window > Dockers > Palettes (or Color Palettes > Palettes in some versions).
  2. Navigate to Spot Colors: In the Palettes docker, expand the Palette Libraries folder, then expand the Spot folder.
  3. Select Roland Palettes: Check the box next to Roland. This will reveal specific libraries such as:
    • Roland VersaWorks: Contains the essential CutContour (magenta) and PerfCutContour colors.
    • Roland Color System Library: Includes over 1,000 spot colors for precise printer matching.
    • Roland Metallic Color System: Used for machines equipped with silver or metallic inks.
landdesigns
Thank you ,I have the Cut contour color and color System library Installed, just trying to add the Green and Orange to the my color palettes to my Coreldraw 2025 , having no luck . I have Orange and Green ink on my Roland .
You do not need 100% those libraries. The regular RVW color library should be ok, and also have those orange and greens in it. I do know if you have Versaworks that you can see those libraries and print them out.
i do not have Corel to test, maybe other forum members can chime in.
