Out of Gamut Colors
I am running into a problem with printing those hard to hit colors. I have been printing using Flexi 12 and the same Mutoh 1624x for years. I have never had an issue with the way Flexi interprets the out of gamut colors as long as it is an RGB file I am sending. Normally if I send an out of gamut blue or red, Flexi is able to get pretty close to the original color. Now suddenly Flexi is outputting a very washed out version of those colors that is not even close. I am using the same color preset that I have used for years as well. Ive attached a photo of the color difference. Please help!
Sign Banner Decal
Sign Banner Decal
We use Flexi 12 and try to always use CMYK to get as close as possible. That said we use about 8 different medias and it's a pain to profile each one.
Sometimes Flexi updates have caused us problems like what you're experiencing. One of the things we have done is we have a large pantone file with different shades of all the colors. We print that on each media so when we're trying to hit a color instead of putting in a pantone we go back to the pantone file and use the color we chose off the print.
bteifeld
Substratia Consulting & Printing;Ergosoft Reseller
The issue with reaching Pantones and other spot color systems is that you need a proper media configuration to start wtith- linearization, ink limits, and ICC profile.
The best color system to use in assuring spot colors is L*a*b*, or more simply Lab- which is an absolute device and media independent numeric expression of the color.
RGB and CMYK are device dependent- they are specific to a color space profile that must define the meaning of the numbers in RGB and/or CMYK.
Often the color libraries provided with a RIP specify the Pantones with L*a*b*. If they don't, and you own an xrite spectro(i1pro/i1pro2/ipro3) or colorimeter(i1displaypro),
you can download Pantone Color Manager, export a Pantone palette(like solid coated or solid uncoated) in either ASE or CXF format, and then import that into your
RIP to define the Pantones properly. You'll need to learn how to use that part of your RIP which allows loading color libraries.
After that, some color specialists may have ways to improve the ink builds that RIPs construct from profiles to even better match the Pantones.
  • Agree
Reactions: 1 user
