Straycatgr
Hello to all. this is my first question here
I would like to ask if someone has done it before. ... Is it ok to use Polyester clear Lamination over a polymeric vinyl? I have found a laminating materialThese that suits my needs but I am wondering if the combination of a vinyl polymeric works well with a Polyester lamination instead of a polymeric vinyl lamination. Will it stand well in time? Also Do you suggest a cold laminating pass or should I use some temperature on the polyester? Forgive my ignorance but I've never done this before
These are the tech specifications of the polyester film.
- Film thickness: approx. 250 µm
- Composition: hardened, high gloss polyester film
- Basic weight: approx. 450 g/m²
- Surface: Smooth
- Glossiness: 60º/85º C
- Adhesive: Solvent-based, clear, permanent acrylic adhesive
- Adhesive thickness: 28 g/m²
- Adhesion (Glass/25mm): 10min. ≤ 1500 24h ≤ 1620
- Liner: 20 µm PET film
Thank you in advance!
- Surface: Smooth
