DL Signs
Never go against the family
All kinds of issues. First I replaced cap tops, one lines up and seals, the other doesn't. Seems to be a common issue, just cleaned head A, periodically, printed with B till I could have time to address that. It gets such light use, I didn't even really have too replace the cap tops, just figured I'd stay ahead of it.
Going to do that this morning, when I turned it on the head wasn't going all the way to it's park/ lock position, it comes out far enough out where capping station stays open, and head just rocks back and forth till it errors when I try to print. While it's slowly rocking back and forth it's also squeaking a little, like something is rubbing. It will test print and that confirmed the head was too far out too seal, yet it was good last week (other than needing adjusting so both cap tops seal). I shut it down and pushed the head back to lock to seal the heads with a little cleaning juice in the cap tops.
While I'm checking to see if the encoder strip or sensor is dirty (fingers crossed it's a simple thing like that), any other known issues with, or fixes for this.
One thing I had to do on our old printer once was set the parameter CLKAJST to "0", also can't do the cap top adjust either because the maintenance menu for the 300 plus is all different than the 300 standard... Soooo, I'm not messing with that till I can find a manual, will manually adjust the capping station if I can get the head to park.
