vroongraphics
Hi. I am using Cutting Master 2 with Graphtec FC7000 series cutter. For some reason, my "cuts" are not going smoothly...it seems like there is a 'perf cut' being done, even though I double-checked and found that "perf lines are turned off on the cutter" and "cutting master 2 shows straight line" option for condition 1...hmmm....
anyone know what the problem could be? this is odd, as I said...the cutter says perf is off...and i did not select any option for perf lines in cutting master....
Thanks in advance....:Canada:
