Please help with Mimaki / Graphtec issue
jerry@SLH
We print and kiss cut stickers with our Mimaki CVJ200-130 using Flexi Complete as a design tool. We would love to be able to perf cut those same stickers on our Graphtec CE8000-60. So far, I cannot find anyone including Chat GPT that can show us how to export the proper cutting file from the Flexi software. Your help if you know the answer would be greatly appreciated.
Goatshaver
Shaving goats and eating bushes
I don't know Flexi, but I'm guessing you will need Cut Mater to setup your layouts to print on your CJV and cut layouts to cut on the Graphtec.
That's what I do from my UCJV to my FC9000.
  • Informative
Reactions: 1 user
Jhbrooks
I'd be surprised if Flexi doesn't already have a built-in way to send files to Cutting Master. They're both made by SAi.
I think Flexi Complete is just the Flexi design software so OP doesn't have the production manager included. If you get the full blown Flexi RIP, you'll be able to add the Graphtec to Flexi and cut directly even without Cut Master.
  • Informative
Reactions: 1 user
Geneva Olson
Expert Storyteller
ok so how does it work? i've been working on this for a while now. How do I get flexi to pause to adjust the blade to do the perf cut. (I have a graphtech fc9000)
Attila Nagy
Just here:
This image is not a real setup, only for showing the pause button. You need to change here the Before Cut command to call the condition used for Perforated cut.
  • Agree
  • Informative
Reactions: 1 users
Geneva Olson
Expert Storyteller
Just here:
Got it. One of the videos I saw indicated that you do the contour cut. then when it's complete, you adjust the blade holder so that it falls in the channel. Then start the second cut file. (the perf cut). At least that's what I thought was happening.
Can I do it that way as well?
Attila Nagy
Yes. Is that what you asked for. It will stop until you confirm the blade holder moved, and continues with Perf Cut.
You could set the Condition for Perf Cut use the same tool position1. and no need to pause.
  • Agree
Reactions: 1 user
