letterworks
This is the best way actually just takes longer. But no issues with solvents and such then.Buffing wheel on an electric motor with compound brick.
Just polished some edges today. Hard to take a good pick with IPhone.
Yes, a solvent wipe can work (and is about the only way to polish lexan edges somewhat.Just try to put glue on mated edge. We did it on thick led signs and panels that need to look extremely good (L’Oreal, etc.). Be careful not to drip and do not touch until cured.
					www.edgefinisher.com
				But the first job with rounded corners after buying that would be a let down.I realize this is probably way more throughput than most people need, but good to know it exists. We have had several projects with 300+ pieces of 24x36 and much larger to polish. We didn't put a lot of effort into learning the flame polish method.
Here's a link below:
EF-200 Edge Finisher
Edge Finisher EF-200 - table-top plastic edge finishing machine for creating a smooth, clear finish on the edge of a saw-cut plastic material.www.edgefinisher.com
