Need Help Pop out stickers
Pski89
not sure the correct terminology to be using, but effectively I want to contour cut the sticker, then i believer it actually called perf cut a rectangle around the sticker, so that when the job is finished the stickers are basicly just handing onto the vinyl but the corners or something, so that I can just "pop" them out and be done.
Is this a setting in versaworks, flexi or is this some sort of custom setting people make. any advise would be helpfull
i have versa works, flexi and a Roland BN-20
Thanks!|!
Boudica
You'll need a cut layer for that in the artwork, name it FLEX_CUT. Then assign a spot color, with the exact same name. VW should recognize it.
Then there is a lot of fine tuning to dial in the perf cut just right.
