cleanslatedesign
This is my second post. The first is in the new member section if you want some background on me.
I'm doing a large outdoor sign, looking for pricing advice. I have started working the numbers and this project has gotten kind of pricey, so I'm wondering what a job like this would typically cost.
Details:
7x12 ft monument (customer handling install with my help. They put in the old one, it's only 8 ft of the ground.) The sign itself already exists and is up to code etc, I am just producing new faces.
Backlit
New plex needed-can actually get the SG 7328 in that size locally
2 logos per side and a total of 7 colors and tight registration
I have redone the artwork to work as cut vinyl. It had way too many colors before and was printed as a one piece decal.
Plan to use 3m 3630 trans. I was going to use the 7100 opaque for the black, but the black 3630 is opaque and would match the look of the other colors. Please correct me if I'm wrong. I am also using some Coburn 5yr brushed Aluminum on there with the understanding that I can not guarantee it for any length of time. When backlit, it is actually translucent, though a little Dark.
I will use most of the vinyl up completely for this, so there will be very little leftover, except the brushed Aluminum, which I have a use for already.
Sign is in Phoenix AZ.
I'm not sure if this applies to cut vinyl, but does it get an over-laminate, or is that mostly for the printed stuff? I've never done over lam on my smaller projects, but they don't see as much sun and weather as this will.
OR...
Should I outsource this and go for the printed method? Can printed vinyl last 5-7 years in the SW? Would it end up costing just as much?
Thanks in advance. That got long... Let me know if I left anything out.
Details:
Backlit
OR...
