PRICE CHECK aisle 2
skyhigh
I was looking for some feedback from those of you who do this type of signage, as to a ballpark price. I have an estimate figured out, but wanted to see what others thought before I submit this proposal.
This will be 2 cabinets (both double sided). The top cabinet (12") will have a lexan pan face, and the bottom will use a flat face that will be divided between the 2 businesses. Both will be white faces with translucent vinyl on the primary surface.
I am figuring on a 8" single pole (I haven't run the plans past my engineering firm as of yet) that will have a decorative cover with a textured finish. I am figuring on a 24" hole, 6ft deep.
The layout of the faces is only a rough draft.
Thanks in advance.
PS. LARSIN Drive is the actual name of the road where they are located..... go figure. LOL
One more thing... the only difference between the 2 examples is the burgundy and green faces.
  • CHARLIE1 [Converted].pdf
Derf
Well I would take my metal fabrication and double the price! then add the Lexan as sold normally, then Art charges and Permit fees, engineer fees for wind load and structure, ??? I'm thinking between $5,000-$7,500
There are way too many veritable involved to give an accurate price..
Just bid it High!! CA style:cool:
Rick
Kinda hard to estimate but this is what I have after looking at a few similar signs I have worked on...but I am aiming a little high.
6900-8900.00 for the sign construction
1950.00 +hourly for waiting for permits-Design, meetings, field verify, engineering, planning/permitting min.
2400.00 Install with inspections hourly after 20 hours.
Thyezer
Why not 1 case with 2 divider bars? Hinged face with the trim cut to the size of panels...and vertical lamps.
I'd go with:
Mat'ls: about 6500.00
Labor: about 4000.00
plus permits and admin/office time @ rate.
For me that would bring it to around... $11.5K ....oh yeah + Drive Time :)
What was your Estimate? Are you doing your own fabrication?
T
Checkers
Hiya John,
My shoot from the hip price is about $11k.
$125 sq. ft. for a single sided sign x 1.7 for double faced sign. Then I'll tack on an extra $2K for the pole, design, permits & installation.
Also, I'm probably way off base because I'm not an engineer, but your foundation sounds a little weak to me.
Checkers
skyhigh
Your finally the "low baller"....hahaha....Actually my bid for this is 14k.
You are correct on the variables.. with the extras I didn't mention, 5k would not cover my cost.
Checkers, you are definately right on the foundation. This was originally going to be 12' to the top and a double pole to boot (6' would have been fine). I'll let you know what my engineer has to say.
Thyezer, the reason for 2 cabinets is the zoning where this sign is going. The max for any 1 cabinet is 32sf. I have been over this with the zoning officer many times..... I can put together 10- 4x8 cabinets (each being 32sf), but I can't put up 1- 10 x 4. The highly commercial area where this sign is going does not even allow LED boards (odd). As for a variance....that is not going to happen in this community.
Fabrication in house will be about 75%. Some extras include... filing all permits, 350 ft of buried electric line, and landscaping around the sign.
Thanks all.
