Price for alumacore sign
cbsigns
I have a request for a sign that is about 16" tall and 12' long. It is going to made out of alumacore. We will have to cut it and butt it together. There will be three colors and we are using Oracal 751. It's a simple sign. It will read "A's Country Store" We are also going to install it. I gave a quote for about $299 for sign and $130 to install. Does that sound right? Thanks again for your help!
Derf
Are you doing it in two pieces or one? I don't know if they make 12' alumacore?
sounds a little low. Can you slam the sign out quick with no back and forth with the customer? As for the install sounds a little low unless you can load up install and get back in 2 hrs.
cbsigns
I will be doing it in two pieces. I will probably have to get final approval of colors and layout from the customer. It will probably take a little longer than 2 hrs to actually load up, drive, install, and come back.
How much would you charge?
Derf
Well if the customer did not take up my time being wishy washy and there are 3 colors I would break it down like this
I would take your material cost X2 then you shop rate x however long you have and will spend on the job including art time.
I would be around 500.00 +/- for the signs
and install I would charge 295.00 if it were simple
Hope that helps
OldPaint
2'x16'=32...basically a 4x8. and you ARE WAY TO CHEAP!!!
ALUMACORE SHEET ................................$90.00
32 sq ft vinyl @ $7 sq ft...........................$224.00
install minimun .......................................$100.00
total....................................................$414.00
and i didnt even markup the alumicore...and iam figuring
intermedite vinyl, HP VINYL would add another $50-100.
Carl Wood
OldPaint - I only come up with 16 square foot sign. Still not enuff info here to give actual cost. . . .especially for the installation . . .brick, steel or wood wall? free-standing on posts - in dirt or concrete ?. . .if on wall how high?
OldPaint
carl your still gona buy a full 4x8 sheet .......to get 2- 16"x 6' pieces arent you? plus you gota cut it........
skyhigh
I think the install, if its not up high or onto brick, is a good price. The material, you will have left is scrap. I'm sure you will use it in the future (maybe), so I would charge for a full sheet (lettered) price. You will have the scrap, but you have the labor to cut.
I think the sign price could be AT LEAST 50 more. I always went by $350 for a simple layout, but have been raising that price closer to 400-450.
gtjet
Alumacore at $90 * 200% (100% markup) = 180
Lettering 18 sq foot approx. at $7.5= $135
Labor/shop rate= 2 hours to setup, cut/weed/mask & apply to substrate = $150
Install 2 hours = $150
Total = $615.00
We would be less than Derf but a lot more than you. Lately we have been so busy that I think our price are a little low. We have actually did a sign similar to this but mounted sheet aluminum to an old plywood sign they already had in place for $595, it was a super easy install, took my son and another teenage helper 15 minutes.
