Price help for installing 300 feet of 6" stripe on corrigated siding
signmeup
The stipes will be about 8 feet off the ground on the side of a new warehouse.
Any advice on this would help me with the quote I was asked for. Should I tape the stripes (2mil vinyl) or put them on without tape?
Adrian
imaSIGNr
Either way you do it, this is not going to be fun....
Unless you could try to talk them into letting you pop rivet strips of aluminum across it instead. It would give it some depth also...It would be worth a try...
We have to ask why vinyl is specified?
There is a big public misconception that vinyl will always be able to replace paint. This job really requires paint - for the installer's sanity and the client's wallet.
imaSIGNr
In this case PRO I'd agree. Paint would be easier to do then vinyl even. After I thought about it ,aluminum strips ( 300 ft. )means a lot of holes drilled and possible water leakage.
n20capri
Why are you guys saying paint? To get that chrisp line your gonna have to mask it off before painting...so thats 4 pieces of tape 300' long instead of just 2 stripes of vinyl.
signmeup
The specs for the job call for 2 mil vinyl. I have to quote based on the specs. It has to match the other buildings that are already done that way.
Adrian
imaSIGNr
Have never had to do that much ...but if you painted I wouldn't mask it. I would just snap a line and brush it in...
imaSIGNr
Adrian
Have you looked close at the other blds.?
If you can lay out about 6-8 ft. of vinyl at a time with a helper. Then just press it down good on the ridge tops then carefully heat gun the vinyl to lay in the valleys. It would work as long as it didn't stretch too much. ..... Only use H.P.
animenick65
imaSign, laying the vinyl down like that depends on the depth of the channel....its hard to see in these pics. That method might not work well or may cause future failure if those channels are very deep.
bcpop
Mask the vinyl. Pop a chalk line along the high parts of the metal. Try not to work in direct sun. Use a wide squeege. I would probably cut my stripe into 8 to 10 foot sections. To me the hardest part is moving the scafolding.
imaSIGNr
That's right, that's why I said "if it doesn't stretch too much ". May have to do a test piece. Apparently there are other blds. that have been done this way, so it may work.....Make sure those channels are clean, no paint chalking, only H.P. vinyl and use a heat gun carefully. That's all you can do. IMO
Mike Paul
Super Active Member
Paint would take longer than vinyl in my opinion.
I'd snap a chalk line and use cast Oracal 751. Get it cut down to 6in. rolls. 751 is a little thicker/stiffer so it would be easier to apply without transfer tape.
Apply right to left and lay it in the channels as you go without heat.
signmeup
Thanks guys. I guess I should try a test section. I'm just not sure if the vinyl will press down into the ridges if I tape it. Or do I apply it to the high points and then remove the tape and then squeegee it down into the valleys?
The ridges aren't very deep, maybe 3/8". If It can be done without tape it will save a fair bit time in not taping it.
Moving the scaffolding will be a big part of the job. I may be able to work from ladder jacks....that would be a lot less to move. The siding is brand new...in fact it isn't even installed yet so I'm not worried about the vinyl sticking.
Adrian
signmeup
Mike,
Thanks. You posted while I was writing my post. So, 1 vote for no tape and 1 vote for tape....
My supplier will cut the vinyl into 6" rolls no charge but he didn't offer to tape it.
Adrian
BrianH
Can you get a lift in front of the building? IMO, you can save alot of time with a lift compared to ladders. Time is money. We do long stripes like this all the time but 40" tall. Just take your time and have a helper hold the end.
imaSIGNr
If you're only 3/8 " deep off the ridges, you're all set...I haven't used the Oracal 751 too much yet, so I don't know what the memory factor is. That's why I said H.P. as in Oracal 851, but yes 751 is thicker and would be easier to do without appl. tape....If you can get your rolls cut to size then, snap a line have a helper hold the starting end while you pull the roll out. Follow your snap line and just press it to to tops of the ridges. Go a few yards, cut it off, go back and finish what you've laid on with a heat gun ( dry )and a felt covered squeegee ( or velcro fuzz squeegee ).Then go on to the next piece....All the while moving your riggin....Two step ladders with two 16 ft 2" x 10" planks will do fine. You're only 8 ft. off the ground.
