Price Help
evader
I am just starting to do my own sign work from home. So far I been doing smaller signs (12" x 24"). I just got an order to do 2 corplast signs that are 4'x8' each in size. I will only be using 1 color of vinyl and the text will be fairly large. In total I will be using approximatly 8 yards of blue vinyl.
How exactly do I go about coming up with a quote to give this guy on the job? I have been told to pick up a copy of "Pocket Price Guide" and I plan on doing that next week (my supplier is closed on weekends). The problem is, this guy wants a quote on the job sometime today. Can anyone give me an idea of what you might charge for a job like this?
Thanks alot for your help.
evader
Thanks alot for the quick response. I really appreciate it. That gives me an idea of the direction I should be heading in.
Thanks again!
GT
Evader,
How much time does it take you to letter one 4x8?
By that I mean set the type, cut the material, weed, mask and apply?
ChiknNutz
Assuming 4mm coroplast, 3M 7025 intermediate vinyl and 80% coverage I would charge $166.08. 3M 7125 cast vinyl would fetch $191.04.
Fred Weiss
Yes, for example at $5 a square foot a 4 x 8 foot board woud be 32 x 5 = $160. I vary the rate per foot increasing it if there is more than average copy, graphics, multiple colors or excess coverage as in layered multicolors. I also increase if the board dimension is less than a full board.
For two identical boards I would probably discount my rate by 5% to 10%.
Coroplast is a strange item. Cut up, you will get a yield of 10 18" x 24" panels with a 6" x 24" scrap. A 4' x 8' white board in my area goes for $6 to $8 depending on who you buy it from. Yet I can buy a box of 50 white 18" x 24" boards for $40 to $45. This translates to 40¢ - 45¢ each if I let the factory do the cutting and 60¢ to 80¢ each if I cut them myself.
Another strange oddity is perceived value. I have no problem charging $3 to $4 a foot more for signs on 3mm PVC foam. Yet the per foot cost is only about 35¢ more. Same thing with aluminum. We buy 4' x 8' x .040" sheets and shear cut them to size quickly and cleanly. With recent increases it's at about $1.10 a foot or 88¢ more than coroplast. Yet we are able to command a price of $5 to $6 a foot higher than coroplast.
evader
Again, thanks for such a quick reply.
One more question. I've been approached by someone who is more into the printing business but says he gets alot of requests for sign work and wants me to be his "sign guy".
What's the best way to deal with this? What sort of price break do I give him as the "middle man" so that he has room to increase the final price for his client?
Thanks again!
Steve C.
We just received the new Commercial Sign Pricing 2005 from Signcraft. A very informative publication. It gives a price of $110 for simple layout, one color. Based on a shop rate of $40 per hour. I assume that your shop rate will be low working from home. I give a discount of 5% for quanity of 2-4.
The Signcraft Pricing guide gives instructions and a worksheet for figuring your hourly shop rate.
Fred Weiss
Thanks again!
That's a whole other can of worms.
The first question is what is he going to do for you. If he is just going to accomplish a sale then you need to supply him or her with type charts, color charts, and predefine all your products. You then set your wholesale based on the least you are willing to produce the work for. For suggested retail, take your wholesale price and divide it by .6 to arrive at a retail price that will give the dealer 40% profit.
If he or she is going to not just sell but plan each job and give you an approved file to produce, then you are assuming the role of a jobber and you should quote each job at the lowest price you're willing to do the work for. The selling price is totally up to the dealer to set.
I would point out that for the last four years, at the end of each year, our highest volume customer has been our local Club Car golf cart dealer. We do whatever sign and vehicle work they need but the main money maker has been a jobber arrangement for personalizing names for the carts. We give them a choice of two letter styles and about 15 colors. They fax over the orders as they get them and we drop off whatever they've ordered on the way home each night. That piece of business has amounted to between $6000 and $8000 a year for the last four years with another $2000 to $3000 in miscellaneous sign and decal work.
Sometimes a reseller can work out well.
