You should still be able to figure this on sq ft + art charge. If there are a lot of different numbers and the quantity of each particular number varies you will have a lot of time into setting up the numbers and I don't think that will justify any discount. Just guesstimating, you probably need 3 rolls if that A-7801R you mentioned is 15" wide (assumptions made based on not knowing more details about the numbers needed).
