Pricing Formula Check
Ogriv
Greetings,
I have designed my own pricing formula for my business. The results for small signs calculate nicely, but the large signs seem to be calculated incorrectly. Here is an example, The attached picture is a job I am currently working on, it is 12ft long by 3ft high. It is 2 color using Avery A9 Pantone Translucent. My initial calculation was $1100.00. Wow that seemed a little high. After manipulating the formula I came up with $691.00. This sign will be sold as "Ready To Apply". I am charging by the square foot, should I start reducing the SqFt price after the sign exceeds a certain size, or should I stick with the higher estimate? There is only one other sign shop in town, and they are not very willing to give out such details.
Fred Weiss
To answer your question, in the formulas that I use, I have a reduction is rate as the work gets larger ... but it reaches it lowest rate at about 10 square feet.
Your post, however, leaves much unknown and raises lots of questions.
1. What you have posted measures 98 x 640 pixels. This is a height to width ratio of 1 to 6.53. If the sign is 12' (144") wide, this calculates to only 22" tall. Not to the 3' x 12' size upon which you say you are calculating your price.
2. The sign is 2 colors which overlay eachother. What is the total square footage of vinyl needed for the job?
3. Transluscent film costs more than normal films. This is fine for the red, but are you also using that type of film for the black which can be a standard opaque film?
4. You call this a sign and you also refer to it a Ready-to-Apply. Are you selling a complete sign face or just the vinyl graphics?
Ogriv
Jim,
It was very early when I wrote the post up and my cold pills had not kicked in. I'll gather the details during lunch and correct my post. To answer your last question, the customer has the backlit sign purchased already and prefers to apply the vinyl himself. So I am just supplying him with the cut vinyl. And yes I am using the Avery A9 Trans for both colors, I prefer not to mix brands and grades of vinyl on a single project, it is easier to troubleshoot later if there is a problem. Sure it cost a little more, but this customer has 6 lighted signs for me to make, so it will go unwasted.
ChiknNutz
Assuming it IS 3' x 12' and vinyl only and customer installed, I'd be WAY less at approx. $436.
If it is as Fred suggests (22" x 144"), then I'd be at $293.
FYI, I use a tiered pricing structure that gets cheaper per sq. ft. the larger it is.
Fred Weiss
Allowing for the black cut to be about 9 feet and assuming the 22 x 144 is correct but counting the 22" as 24", we have 24 square feet of red and 18 square feet of black for a total of 42 square feet of cut transluscent series vinyl.
That puts your quote, Chris at about $7 a square foot. I show the current cost at list for A9 Transluscent at about $2 a square foot. Speaking for myself, I wouldn't do this just for less than $10 a square foot and, depending on the client's potential and the size of the order, would probably be more in the $12 area.
My price would be in a range from $420 to $504 based on the 22 x 144 it scaled to.
Ogriv
I found the error in my formula (Too much multiplication, which is great for profits, but bad customer relations). Once I fixed the formula and re-ran the numbers, I came up with $340.00. I called the customer and he replied "That's great, when can you have it done?"
So I got the job :thumb:
Thanks for the input, I knew there was a problem with the math, but I have been fighting the Flu and my mind has been wandering lately with all the meds the Doctor gave me .......
ChiknNutz
I show the A9 to be $1.42/sq. ft. from Ameriban (based on 24" x 10 yd roll) - which I had as $1.33 when I quoted. I also used a 50% markup. For vinyl only, maybe 75-100% markup is more in-line. I also don't double the price for subsequent colors - maybe I need to rethink that part.
Ogriv
I kept the lower price, because I knew that the customer had more signs for me to do. Had I only gotten the job for the one sign, I would have chosen a higher number. I still make a profit from this sign, plus I'm guaranteed more work! The customer is happy and I am happy!
