Pricing Help
mbarden
Hi Folks,
Thanks for everyones help. I am going to hopefully get an estimate signed for this sign. I have it priced between 112.56 and 130.00. The sign is on 1/4" Alumilite and is 24x30. How do you handle it when you are starting out and have to cough up 92 bucks for a 4x8 sheet of substrate. There goes the whole job cost.
Mike B
Big River Sign Co.
bob
Hi Folks,
You mark up the entire sheet and make this client pay for it. The next guy gets to pay for a whole sheet as well, even if what it want cuts out of what you happen to have. Unless it's some small insignificant thing that fits on some scrap you happen to have. Even then you charge the marked up square foot price. I've sold the same sheet of Alumalite 4 or 5 times.
What you can do to ease the pain is offer to do multiple copies for relatively cheap. Here in my shop the first copy would be around $200. Subsequent copies about $60 per each.
If you don't do this you're going to be stuck with a car load of oddball chunks of substrate that you may or may not ever use for anything. The gods of perversity dictate that what you need never cuts out of what you have.
Body shops do this all the time. You buy a quarter panel, they cut out just the piece they need . The next guy buys the same quarter panel and gets just the piece he needs.
ENTDesign
Does this have to be on alumilite? I would ask if the customer could accept 0.040 sheet aluminum or steel, which you can get 24 X 36. If not, I would build the cost of the full sheet of alumilite into the price, as the remainder is scrap. What you do with the remainder is then up to your creativity later. I admit I have not had to do this with alumilite yet, but have done so with 6 mm expanded PVC sheet. I would probably be $150 (but my alumilite is a little cheaper than you are getting).
threeputt
Most of what I've read is silliness. At least from my point of view. Buy the sheet, bite the bullet. Around here a 1/4" sheet is about $100 bucks. Can't imagine that being any kind of hindrance.
Our price for a single-sided sign of that size and complexity is $129.00 so you're about right on that score. Knock out the job, so now you've traded your time and some money for an entire sheet of material. Next job comes along, bingo!
It's true this forum is for beginning shops, but seriously, if you can't spring for a little bit of materials, you're so under capitalized you won't make it. Decide on how important your livelihood is and go for it.
Good luck and prosper.
