Pricing Question for some sign Gold
Blazingsun
I have a client that needs there front window done on there store, The Logo will be 30x36 two colors Black Lettering (The Black Lettering needs to be discussed some more with Client) with a 22kt gold Fancy Frame.. I will be using sign gold to do the gold work..
This stuff is expensive to begin with and was wondering what the going rate is for something like this?
Thanks in advance..
jimdes
Sign Gold on a window . . . . hmmmm. Depends. Poor visibility and the effect won't show on a second surface application. You really have to use it on first surface applications only. Also, as I remember, Sign Gold is only available in 15" widths so the logo would have to be paneled.
A less expensive alternative would be the Coburn "Heavy Metal" series of films.
seaviewsigns
i usually double my cost on the signgold used and go from there, adding any other expenses. i'm not sure if this is high or low, but it's worked so far. i'm interested in what people say too. here's a pic of a dump truck i did last weekend.
also, you can get it in 24"
Colin
Nice design! But it is so very weak due to the thin outline used. When placing gold (of any kind) on a white background, you need to use a heavier outline - even better with a shadow. I feel it ought to be a little larger as well. The most legible thing is the phone number - the opposite of what should be happening.
seaviewsigns
i went back and forth with this guy... that's what he wanted. there were other options that were much more pleasing to the eye, but this is what he wanted. he actually printed out the comps i e-mailed, cut and pasted the paper together to get this. he's very happy with it and was standing there with a check in-hand as i was cleaning up.
