itschillin
Is anyone having this problem where the cut is off by 1/32" for the entire sheet? It does not matter if I cut a small job or a large job. It is consistent throughout the entire sheet. It not that bad until I have to cut small letters or text that has a color outline. This may not be related but in Versaworks I can zoom in and it doesn't seem right. If I rotate the image the cut lines seem to move but it always cuts the same. When I check the cut line in the original file in Illustrator, it looks good. Is there maybe a way to adjust the cut at the Roland?
![Help :help :help](https://signs101.com/images/smilies-orig/standard/help.gif)
Thanks for your help,
Troy
Troy
