Stormyj
Just another guy
SC540I printed an image, had the printer print registration marks, everything worked fine. laminated print, put back into printer, aligned registration marks, used auto align to do it, went to cut, but the cut was smaller then the print. It looked like it knew what it was doing, but the actual cut line was probably 40% smaller than print image. I did cut the material down and resetup so the size of the material was smaller. Would that cause it. I will try again, but takes a while to print and laminate. Any ideas??
Its a fairly easy cut so I will had cut one so I dont have to waste time and material, just want to know for next time.
