Printer Suggestions for 2027
Think713
Curious to see what anyone's input is on new print technology, and whether or not there are any printers or new inks they are looking at, or using that is worth the investment. Could be anything from Latex to Solvent printers. Extra ink colors, etc... What are yall looking at/using?
dtfonestop
Good question to be asking before budget season. A few things I'd weigh rather than chasing any one model:
1. Start from your real job mix. Pull the last six months of invoices and see what you actually printed: vehicle wraps, banners, wall graphics, rigid signs, window work. The right printer is the one that covers the 80% you do every week, not the one that does the rare job best.
2. Latex vs. solvent mostly comes down to turnaround and environment. Latex comes off the printer dry and ready to laminate or install, which helps a lot if you're doing same-day work, and there's no outgassing wait. Solvent and eco-solvent still give a lot of shops the color and durability they like on outdoor work, and the ink cost per square foot can be friendly. Both are proven, so it's more about how your shop runs.
3. Extra colors are worth it when you have the work for them. Light colors smooth out skin tones and gradients for photo-heavy work, orange/green help with brand matching, and white opens up clear and window films. If you rarely do that kind of job, the extra channels mostly mean extra maintenance and ink sitting in lines.
4. Look hard at UV if you do a lot of rigid signs. Printing straight onto ACM, coroplast, acrylic or wood skips mounting and laminating on a lot of jobs, and it's where a lot of shops have found new work in the last few years. Roll-to-roll UV and hybrid machines are worth a look too if you want one printer that does both.
5. Count total cost, not sticker price: ink per square foot at your coverage, maintenance ink and waste, service availability near you, how long parts take to arrive, and how much floor space and power it needs. A printer that's down for a week waiting on a part costs more than any ink savings.
6. If you can, go see the shortlisted machines run your own files. Print the same job on each and put it outside for a while. That tells you more than any spec sheet.
If UV ends up on your list, you can see nearby Audley dealers to watch one run in person. What kind of work makes up most of your week right now?
  • Disagree
Reactions: 1 user
Smoke_Jaguar
I am pretty sure variable dot size is still going to be treated as a new technology 30 years later. Definitely look into that.
As for Audley printers, they are pretty mid. Nothing new coming to the table but built to be average. Just another Hosonsoft board-based printer.
