Joesignshop
I have had an ongoing issue with my printhead carriage height on my VG-640. If it is in LOW setting it will almost always strike it slightly skip cast vinyl which is thinnest. Vacuum works as it should, roll is always squared up with no buckling. Something is incorrect as I had an XC540 that would adjust correctly between high and low for materials with no strikes. I also have inspected the printhead surface with a magnifying glass on an old printhead from being docked in low position and it appears that its so tight that it may be deforming the surface where the captop makes a permanent ring, therefore going through printheads frequently. Also its deforming captops quickly on low settings docked. Is it possible when it was manufactured that its a mm too high? Btw it prints nicely on high setting, but am also worried that the high setting on captops is not enough for complete sealing on captops! I wish there was a medium setting on the VG. Goldilocks situation here! Im hoping there is a mechanical adjustment to ever so slightly raise the entire printhead carriage but not get out of alignment?
