Printing Banners/flex face
mya879
Does anybody print banners? We are running an Epson Surecolor s80600 and i cant seem to avoid the head striking. Any media setting suggestions?
Hoze
I would love to help, but im not an expert on Epson, however that might be happening due a suction or heat issue.
bulpoint
this could be a problem while installing the media, the feeder and take-up mechanisms may not be adjusted correctly
signrios
do the head adjustment, i used to have this problem all the time. solution was very simple
DJAvocado
See if you can raise your head some. You might need to turn off the printers curing heater we've had that cause banner to bunch up. If your shops humidity is really high that can cause it as well.
  • Agree
Reactions: 1 user
DannySanti
I have S80 and S30 turn off all heaters except the front heater
