Click to Support Signs101 ...
I have a multiple layers illustrator document that I would like to print without having to select and de-select layers and print one at a time, is there a way to just click print and select a function to print all layers on seperate pages?
If you did that you'd end up with about ninteen thousand printouts due to how illustrator treats it's layer/object metaphors.
Create multiple art boxes on your pasteboard. That way you can work on multiple comps from within the pasteboard without this particular problem (which I assume is your goal here).
