PRINTING TO PVC PANELS
Robot Man Machine
"Follow the sun to reach the stars."
I am printing to PVC panels roughly 24"x36". Using Signs365.
Design fonts are: OpenSans, 24 / 36 / 48 / 100pt
Light bone white background, 4/6/14/0 with black fonts.
My question: Should I design these panels with a regular 100% black or should I use a rich black? My concern is the fonts are too small for a rich black and it will show the cyan & magenta. Please advise :)
lenard912
I’ve had better luck printing directly to PVC when the sheet is actually rated for digital printing. Regular PVC can look fine at first but adhesion can become an issue later. I usually clean it thoroughly with IPA and make sure the surface is completely dry before printing. If the particular PVC still gives poor adhesion, I’d switch media before trying to compensate with printer settings.
Grizzly
It’s all about your print!
Typically a enriched black of 40,40,20,100 will give good result. But I'd ask Signs365 what they're preferred black is. Sometimes they have color replacement tools for 0,0,0,100 to print a really nice black.
24pt font should be find. I print down to 4-6pt reversed. You have to be really dialed in though and I'm not sure what kind of QC signs365 has for that expectation.
Reactions: 1 users
Robot Man Machine
Thanks for this reply. I'll reach out to Signs365 and ask. Really appreciate the guidance...
Think713
flatbed printing to a substrate doesn't change your ink load depending on your selected color for black. It changes in the media profile for how much ink density is allowed to get dropped by the machine. So whether you choose a rich black or regular black or whatever, doesn't matter at the color level.
dannyd1962
Remote Freelancer
Outline your fonts and flatten your image file, otherwise your nice looking file will come out looking like a shitshow once Signs365 processes it.
Marie
I send files to Signs365 in RGB format with black set to 0-0-0, and it usually looks really good.
Sofia Lucas
Blue Dot Signs
I'd go 100% K for the small text, especially since it's going to a trade printer where you can't control registration. Rich black is great for the big headlines and solids, but on 24–48pt type any slight misregistration shows as a color halo. A common split is 100K for body copy and a modest rich black (around 40/30/30/100) for the large elements. Just make sure the small black text knocks out cleanly on that light background, and convert fonts to outlines and flatten before sending the file out.
Think713
There isnt going to be a registration issue on a color choice. That isnt a thing. What CAN happen is static that is on the material can pull ink droplets away form its position its supposed to be laid. So while that appears to be registration, there isnt anything a printer is doing to set registration on a piece of PVC. Thats just not a thing. IF you are experiencing different ink colors around a rich black, that means the printer has not aligned the printheads sufficiently.. So if you are experiencing that in house or somewhere else, that is a user/operator error. Not a registration issue per the file based on color.
