Problem with output size in Flexisign Pro 7.02 production manager
SSOO
I have been using Flexisign Pro 7.02 on a Windows 98 machine for about 7 years with no problems. About two weeks ago the hard drive finally gave out and I re-installed Flexi on a new hard drive with Windows 2000.
Everything seemed fine until a few days ago when I noticed that the output size in production manager was adding to the height and shrinking the width. For example, a line of text that is 8" tall by 38" wide now outputs to 8.19" tall and 37.35" wide. I tried adjusting the percentage but that didn't work.
I'm not 100% certain the problem is caused by W2K since I didn't have any problems to start with. (I actually compared a copy of the same line of text that I cut before this problem started and the measurements for the newer one were definitely off). I searched the Flexi manual and there was nothing about the size option.
I was going to just re-install Windows 98 but I thought I would check here first as I would really like to keep W2K if possible.
I am not interested in upgrading to a newer version of Flexi as this version serves all my needs. Also not interested in Windows XP.
Any help or suggestions would be greatly appreciated.
Addl. system info:
1 GB memory
Summagraphics D60 cutter
Thank you - John
