I have a intersting problem with Flexi 8.6 on windows 7 64 bit and my q42.  It will cut fine, sometimes for a while, or sometimes only a few minutes.  I set my contour adjustments up on the q42 to compensate for a little machine error, and set the pressure.  I'll print, go to contour at first it will cut perfect, the at some point during the contour job it will change pressure and loose the x-y axis corrections and mess the job up.  At that point the q42 will no longer allow pressure or speed changes (error message comes up when you press conditoin button)  and I will have to reset the q42 back to factory settings and start over.  Anyone seen anything like this?  Sign warehouse tech guys have helped alot but no solution yet, my computer guy is working on it to and no answer yet as well.  Not sure what to do.  I have wasted alot of material at this point and am very frustrated....
Steve
Steve
