ledbe
The WS2812B Programmable Full Color LED Strip Lights, the 5050 SMD LEDs built-in WS2812B IC for individually addressable, white and black colors of PCB board available, 30LEDs/60LEDs/74LEDs/96LEDs/100LEDs and 144LEDs per meter available, the length you can take from 1M to 5M pe reel. both ends come with 3pin JSM-SM connectors, easy to connect the controller to achieve hundreds of amazing lighting effects, you can use to DIY any signs.
Link: https://www.ledbe.com/5vdc-individually-addressable-rgb-ws2812b-led-strips
Features:
Features:
- Working Voltage: DC5V
- LED Type: 5050 RGB SMD LEDs
- LED Quantity: 30LEDs/Meter, 60LEDs/Meter, 74LEDs/Meter, 96LEDs/Meter, 100LEDs/Meter, 144LEDs/Meter
- IC Type: Built-In IC WS2812B(The Upgraded Version Of WS2812)
- IC Quantity:30PCS/M, 60PCS/M, 74PCS/M, 96PCS/M, 100PCS/M, 144PCS/M
- Individually Addressable
- Grayscale Levels: 256
- Angle View: 120°
- Power: 0.3W/LED
- Emitting Colors: Full Color 24-Bit
- Colors Of PCB Boards: White/Black
- Lengths Available: 1M, 2M, 4M, 5M
- Width: 10mm(30LEDs/M, 60LEDs/M), 12mm(74LEDs/M, 96LEDs/M, 100LEDs/M, 144LEDs/M)
- IP Rating: IP30 Non-Waterproof, IP65 Coating Waterproof, IP67 Silicone Tube Waterproof
- 3 Pin JST-SM Connectors Included
- Compatible With K-1000C, SP110E, SP105E, SP108E, SP110E, SP106E, SP107E, SP501E Programmable LED Controllers
- Working Temperature: -20°-+40°
- Wave Length: Red: 620-630nm, Green: 515-530nm, Blue: 465-475nm
- Every 3PCS LEDs Can Be Cut Off
- Lifespan: 50,000 Hours
- 2 Years Warranty
