Rasterlink 8 Job Creator Broken?
Goatshaver
I never knew RL7 had this and now I'm on RL 8 I wanted to try it out. Got a template setup from a previous job. Dropped in my PDF print files assigned them to the layers they go with....hit create...it says check RL8. I look and there is nothing going on at all.
I feel like there is something I need to install or have a directory or something where these jobs get created. This would save me literally hours worth of time setting up dozens of layered files I need to print. (Pulling hair out)
dtfonestop
I went down the same rabbit hole the first time I tried it. The Job Creator doesn't build anything on its own, it hands the job over to RasterLink, so "check RL8" with nothing showing up usually means the handoff is failing rather than the template being wrong.
The first things I'd look at: have RasterLink 8 already open and sitting on the main screen before you hit create, with the printer you want registered and selected as the active one, because if RL8 is closed, still starting up, or pointed at a different printer, the job just goes nowhere. If you've got more than one printer or an old RL7 profile still in there, make sure the template is tied to the same printer name RL8 is using now, since templates carried over from v7 don't always line up.
After that it's worth trying the simplest case, one single-layer PDF with plain CMYK, no white or clear. If that one comes through, the problem is in the layer mapping, and the usual cause is the spot color or layer names in the PDF not matching exactly what the template expects, including capitals and spaces. If even the simple one does nothing, I'd close both, right-click RasterLink and run it as administrator once, and check that Windows security or your antivirus isn't blocking it, since the two programs talk to each other locally and that connection gets blocked more often than you'd think. Running the Mimaki updater to get the latest RL8 build is worth doing too, the early v8 releases had their share of quirks.
Once it does work it really is a big time saver for repeat layered jobs, so it's worth the fiddling.
Goatshaver
Ok. I tried just a single layer gloss and it started to RIP and then I checked the log and said "[RIP] Failed to read the file : [{0}]"
I never used this in RL7 as I never even knew it was a thing.
Hot folder setup might've gotten changed, check it out in settings.
Where does this send these files?
