Rasterlink and Frame Cut
sbouey
Hi,
With rasterlink 7 & 6 i want to make Outer Frame Cut (individual) after the CutContour (spot Color)
my CutContour use a Tool CUT5 (user definition) and my Outer Frame Cut (individual) use CUT6 (user definition too)
i printing stickers with rectangular shape with a lot of cutcontour inside , it's why i want to make all the individual Outer Frame Cut to be done after CutContour for all stickers
and all is 1 time without disabling the CutContour for the spot color and enabled the Outer Frame Cut
i have tested with the sort (enable / disabled) but it's change just the way the cutcontour is done.
Do you have an idee to allow this ?
Ps: individual Outer Frame Cut work on rasterlink 6 but not on rasterlink 7 with user definintion)
WizardWorks
I was trying to get it to work as expected last week and eventually put in a service call.
I set the job up in rasterlink as the manual says to.
The job executes on the printer without errors.
The first copy is cut perfectly as expected, with the spot color path cut using one profile and the outer cut using the full cut from the panel, and I can watch the display on the panel as it changes which cut profile it's using, it scoots over for the next copy, switches to the spot cut profile then from that point onward, it stops switching cut profiles and does the remainder of the job with whatever cut profile is defined for the spot path.
I've tried setting the profiles on different numbers and in different orders, different cut combinations etc, the results are always the same: One perfect kiss with full outer cut surrounding it, then both cuts at kiss depth for the rest of the run.
GP
sbouey
I'm not sure to have understand everything , it's work or not ? or it's work only for the first one ? do you have screen capture of your configuration ? rasterlink 6 or 7 ? do you use Outer Frame Cut individual or a spot color CutContourHalf
- rasterlink 6 set with a Cutcontour CUT1 and Outer Frame Cut individual with a CUT2 work but , the Outer Frame Cut is not executed after all Cutcontour changing the sort only change the way the CutContour are done
- rasterlink 7 set with a Cutcontour CUT1 and Outer Frame Cut individual with a CUT2 don't work only CUT1 is used. (i haven't tested yet with the last RasterLink 7)
Stéphane
