Well Michael, all I can tell you is what I just went with, and that’s the RE-640 + cutter. (I haven’t even taken delivery) I’ll tell you a couple of the deciding factors (not counting the input and advice from members here)
1) I had the room for the separate machines and I hope to grow into the added capacity that two separate machines will offer.
2) 10 inches – and after all, who doesn’t prefer a couple extra inches…
3) I did NOT need the metallic or the white options
4) If I’m going to have to print/laminate/cut anyways, then the fact that the printer and cutter is all in one is more of a hindrance than an asset.
I hope that helps you decide. The two packages I was looking at were a grand total of about $300 different between the two – and well, money just wasn’t the biggest factor to begin with.
