RE: Efi Pro 16H
garyroy
We have one at our shop and it has been working great. Recently we noticed an almost complete drop in vacuum in the 4th zone.
The on off ball valve works. All the black hoses are connected underneath. The vacuum pumps are both roaring.
It's just that the 4 zone furthest from the user interface and closest to the docked print head is very weak.
Won't really hold the material down.
Any suggestions from fellow 16H users? We'd appreciate your input or experience with this problem.
Pj lima
hello
could that zone of the conveior be clogged if you print to much on the right side some spray could make it
try to wash the carpet
dtfonestop
Since the pumps are pulling fine and the other zones hold, I'd split it into two questions: is the vacuum getting to zone 4 at all, or is it getting there and leaking out the top.
Pull the zone 4 hose off where it meets the table and feel the suction at the hose end with that zone switched on. If it's weak at the hose, the problem is upstream: a valve or flap for that zone that isn't fully opening even though the handle moves, a hose that's collapsed or cracked somewhere along the frame, or an inline filter for that zone that's loaded up. If it's strong at the hose but weak on the table, it's the table side.
That end sits right next to where the carriage parks, so it collects ink mist and overspray over time, and a lot of holes can close up without it being obvious. Lay a sheet of paper over the zone, see where it doesn't pull down, and clean those holes out. Also look for any open area inside zone 4, like a gap past the media edge or a damaged patch of the table surface, since one open spot can dump most of the vacuum for the whole zone.
Did it drop off all at once, or fade over a few weeks? Sudden usually points to a hose or valve, gradual usually means clogging.
