registration marks
cruiserto
please help! I have had a graphtec robo pro and I have learned many things But what I cant seem to figure out or get an answer to, is registration marks. I am useing corel draw and useing cm2 to print where I can add registration marks, but I cant get it to work What I want to do is have the ability to make a 2 color vinel sign with dots so I can line them up upon application I am pretty sure layers are involved but How do:thankyou: I get the dots?
cruiserto
No thats not what I was looking for, those marks I believe are for a printer so the cutter will see them. What I am looking for is done strictly with a cutter . What I have seen and want to do, is have the cutter leave a mark typicaly a dot than when another layer is cut in a different color the dots will line up for proper application :thankyou:
amw
Longtime Members
What was said above.
And if it makes it easyer...
Basicly put 4 (or however many you want) squares around your design, then cut the design...and the squares. Cut the squres with each color (so you sould make them a dif color then everyhting else). Now you have your registration marks.
Marsha
cruiserto
Thanks everybody I guess I was on the right track but fell off thinking there was a more complicated way LOL Glenn
cruiserto
kept poking it
I think everyone has helped me on the correct path.... But tell me if I am wrong, I printed my letters useing print under corel drop down and after going into it their is an option to add reg.marks (target type ) I am pretty sure it is working with cm2 I tried it and it worked, but I havent tried layers yet to get colors
