removal
WOODBS
just checking what you guys are getting per hour for cut vinyl removal. we have a fleet to remove all vinyl, i have not seen the vehicles. i'm thinking peeling and rubbing glue off? pita
SignosaurusRex
No offense there Woods, but aren't you putting the cart in front of the horse here? You damn well better get an Idea of what you are up against! Do a test removal and find out what you are dealing with. If you are not able to do that , than you gotta go with an open-ended time and materials quote. You are dealing with multiple vehicles of which you don't know if/which ones were wrecked and relettered before a proper gas-off time occurred, what materials were use for the graphics, etc.
I don't envy your homework. I've seen vehicles that cost way more to remove the graphics than it cost to design, produce and install the the originals, and by the same token, took seconds, not minutes or hours to remove. Best Wishes!:wink:
weaselboogie
$40 per hour. Give them a VERY broad estimate on time. Figure worst case
But the big thing is letting the customer know what the price is. You'll be surprised how quickly they'll decide to do this on their own. Explain how "easy" it is to do. That will also do some motivating.
Whats with all the bumping? Are they waiting over your shoulder?
WOODBS
exactly my thoughts..i have a slight idea now , they are full size vans with text on the upper rear, and a solid stripe on the beltline. it doesn't look as bad a s i expected. but 40 is too low , i was thinking 65ish
SignosaurusRex
We do an incredible amount of removals. Its very easy to either make bank or loose your ass if you are not properly prepared with your homework completed and all of you punctuations anchored.
WOODBS
apparently the guy has 10-12 subs removing all decals and i will just be another grunt. we'll see
SignosaurusRex
Well prepared, you might be able to make better $$$ If paid by the unit rather than the hour. Just a thought.....Will there be a "Reletter" or new work in it for you....or someone?
WOODBS
?? this is a cool guy i met at wrapquest who is a pdaa member, so may bring future work. he is installer only, no production..
