Replace colors
daenterpri
In composer is there an easy way to replace ALL of a particular CMYK color with a spot color without having to select every single section of the graphic with that CMYK color? I try dragging a spot color over to that particular CMYK color in the swatch at the bottom of the program, but it doesn't seem to work.
Thanks!
Fred Weiss
Use the Select menu to select from the process colors in the job, then click on the desired spot color on the spot color palette.
