Replacing RV Vinyl
vinyldesignz
Hey all,
So i have a parents friend who would like to replace some of the vinyl on their RV with another color. The vinyl goes from about the front of the rv all the way to the back on each side, as well as a strip around the backside of the RV. Looks similar to this:
They want to replace the blue vinyl with a solid maroon color. Anyways, the RV is about 35 feet long I think so it would be about 32-33 feet on each side and probably 6-8 feet for the back.
What would you charge for something like this for removal of old vinyl plus the new stuff?
Thanks,
Mike
Service Sign Co
I tell the customer you never know what it cost removing old vinyl until you test a spot to see how easily (or not so) it comes off. You still can run into problem areas. Some of those rv's can be a pain,a lot like reflective. Usually suggest a 45.00 per hour rate.
PGSigns
If the old vinyl is in good shape and they just want to change the color you may want to concider overlaying it. You need to be good with a exacto to trim it once you have the new stuff on but you don't have to worry about removal or ghosting from the old stripes.
Jimmy
