rip it to pieces
belongie
ok, here is my attempt at a logo. let me know what you like (if anything:rolleyes: ) and what you dislike. Any suggestions would be greatly appreciated. You people are my heroes! well maybe not heroes, but you get the idea:U Rock:
If you can't tell, logo design is not exactly my forte
ps this is what part of the alphabet would look like if q and r were eliminated
DRPSignsNGrafix
I don't like the font on teh signs and graphics part. hard to read. on the "new" part good idea with the welding, but the NE looks funny. takes a second to figure it out. Just my .02 cents
S
Sign-Man Signs
Guest
Think it looks o.k., but I would put a background color to it. May make your graphics pop out better.
Craig Sjoquist
likes the design maybe NEW a bit strong tho .... but mordern looking just needs somthing not sure what or how yet .
thank you n enjoylife
belongie
Any suggestions on font for the signs and graphics? Maybe put that copy in a box? What are your thoughts on the "&"? I don't know how I feel about it anymore. Thanks again!
Nate
bob
It must be Serpentine's turn to come around on the big wheel of overused and incredibly trite type faces. I seem to see it everywhere this past week, and none of it good.
Other than that, which is sufficient, what you have here is a couple of lines of discordant text, colors, and effects. Just like someone else's attempt at a logo in the last few days, bad color, worse typography, and non-existent design. Try again. This time go for some sort of balance of elements, non-convulsive colors, and effects that actually have some effect other than to confuse.
Something that is said well is said simply.
Ken
I typically stand back about 10 feet or so from my monitor to check the clarity of a design. ( Or squint).
Two things I noticed:
The ampersand with the circle confuses the text that is overlaid on it. But I do like that layout.
If the ampersand (&) was the same color green as NEW that should help.
The "G's" with the small side stroke look very much like "C's"
You could try spacing that font out a little.
I dont have a problem with "new".
You can play with color forever. Red/orange/brown is warm. Green/blue/grey is cool.
I disagree with Mr. Acerbic that design is non-existent here. His head is in some kind of cloud..could be Earth smog.
Cheers!
Ken
belongie
well I know that the font on the signs and graphics is not working, but I need to get to sleep. This is just a quick little sketch. I think it works better with the copy and ampersand. Is this color a little less painful to look at bob? I really appreciate constructive critisizm sp?, and will use it to better myself. So, thank you to all who gave me good and bad points in my design. It really is helpful.
bob
OK, second round...
The 'Signs & Graphics' looks fair to middling on a monitor but you might have problems executing it on a sign or printed matter. The reason being is that it depends on the powerful true white of a monitor to make it work. Something not available on a sign or printed media. I do rather fancy the ampersand as part of the background. Good there.
Now on to the 'NEW' in which lies a number of issues. Is that the best color you can come up with? It looks like a K Mart going out of business sale that's faded in the sun.
As to trying to make your own ligature, this is seldom a good idea. All the really good ones have already been done and the 'NE' is not among them. The problem here is that you're using a thick and thicker typeface and the way you've done it ends up thick, thicker, and lots thicker. Another problem with this, and most, multiple thickness faces is that the 'N' has a thin right hand vertical and the 'E' has a thick vertical. If you make the shared vertical thick the 'N' doesn't seem to look like an 'N'. If you leave the thin vertical then the 'E' fails to look much like an 'E'. Part of recognizing and comprehending the written word is the ability to read it without actually seeing it. You anticipate letter shapes, you've been looking at them non-stop for most of your life. When you abuse this you get discords. Often these are a Good Thing, just as often they are not.
The name 'New' is itself problematic. Is it your name or is it just a tag for this business? Either way, it's less than an optimum choice here. I once new a fellow named Chris New who was in the roofing business. Most of his business was in repairs but he styled his business 'New Roofing'. Needless to say his target business suffered because of his choice of name for his operation. While the effect might not be as acute in the sign business, don't artificially limit your market by a dubious choice of name. No one ever lost money over-estimating the human capacity for stupidity.
Deaton Design
Try doing all your designing in black and white first.
If the design looks good in black and white, it will look good in color. Wait and add effects if need be, after the design is finished. You've got a good start here, just dont worry about colors and effects and such until you have the type and graphics (if any) nailed down.:)
