ROCESSING” during startup
Micro01
Hi everyone,
I have a problem with my Roland VersaCAMM VS-640i.
When I turn the printer on, it starts normally. The print carriage/head moves back and forth during startup, but after about 20 seconds the machine freezes completely on the “NOW PROCESSING...” screen.
The control panel becomes unresponsive and none of the buttons work. The only way to turn the machine off is by using the main power switch.
This problem used to happen occasionally. Before, switching the printer off and back on would solve it. Now it happens every time and the printer will not complete the startup.
I have already tried disconnecting the Ethernet/network cable and USB, unplugging the printer from the mains, waiting, and restarting it, but the problem remains.
There is no error code displayed.
Has anyone experienced this exact issue on a VS-640i?
Could this be a main board, power supply, servo board, sensor, heater, or another startup initialization problem?
What should I check first before replacing expensive boards?
Any help from a Roland technician or someone who has repaired this issue would be greatly appreciated.
damonCA21
It is most likely the mainboard has failed. The power supply is fine as you are getting the control panel on and it is starting to boot up. A sensor issue with a good mainboard would give you an error code, the same with the servo board and heater.
  • Agree
Reactions: 2 users
Actually it is most likely the panel board. I have already had two VSI’s this year with the same symptoms. It turned out to be the panel board.
however, please undo the ethernet cable and try your turning on again and see if it still goes into Now processing
  • Agree
Reactions: 1 user
Micro01
Thank you for your help. It turned out that the problem was coming from the panel board cable, specifically one of the pin connections. After fixing/reseating the pin, the machine started working normally.
  • Agree
Reactions: 1 user
