Roland BN20 RIBBON CABLE BETWEEN MAIN BOARD AND HEAD Right Connection
bil
Hello everyone, I hope you're all doing well.
I'm currently working on replacing the ribbon cables between the main board and the print head of a Roland BN-20, but I've run into a bit of confusion after reviewing the service manual.
On page 131 of the manual, the connections are listed as follows:
Main Board -------------------- Print Head
CN6 (29 pins) ---------> CN3 Front
CN8 (28 pins) ---------> CN4 Front
CN5 (29 pins) ---------> CN4 Rear
CN7 (29 pins) ---------> CN3 Rear
However, elsewhere in the manual—specifically in the connection diagram page 27— i could say that 28 pins ribbon cable is connecting to CN5, with the 29th pin marked as "NC" (Not Connected). In that version, the connections are listed as:
Main Board --------------------- Print Head
CN6 (29 pins) ---------> CN3 Rear
CN8 (29 pins) ---------> CN4 Rear
CN5 (28 pins) ---------> CN4 Front
CN7 (29 pins) ---------> CN3 Front
This discrepancy leaves me uncertain:
- Should the 28-pin ribbon cable be connected to CN5 or CN8?
- Which set of connections between the mainboard and the printhead is correct?
I've attached pages 27 and 131 of the service manual for reference.
Any clarification or guidance would be greatly appreciated.
Thanks in advance!
Richieb
Thanks in advance!
Hi if you look at the first page you have sent page 27 the diagram shows cn5 does not have a connection to line 29 all the others do ?
The best thing is to always label all four cables on the print head as well on the main board and pay attention to how those came out so you can put them back in correctly. Yes the second one back on the print head from the front is the high voltage cable and that is the odd one. They go back to the main board in line one through four.
bil
Hello Richieb,
Yes i had to verify the right cable connection on a working roland BN-20, and sorry that i did not update the post.
The right connection is on the page 27 of the manual as follow:
Hope it could help.
Bil
