wildchildc1
I recently purchased a Roland Camm-1 PNC1000 plotter.. I havent been able to obtain the manual from the original owner and I am having comunication issues.  If I use a 25pin/Paralell cable, the plotter will spool up the fan and cut some type of code when I hit the plot button, but other than that I cannot get it to cut. I have purchased numerous different cables and downloaded every driver I can find for this model cutter and I still cannot get it to cut. I dont know if Im not installing the drivers correctly since I can unplug this cutter and plug my other cutter into the port and it still works fine.. Or if I do not have the correct cable because I was told they use a special cable, or what my problem is exactly?? I know that Ive had the cutter for about 6 weeks and am pulling my hair out trying to get this thing to cut.
If anyone can give me some technical advice and help.. email me a manual for this machine or anything of that nature that would help me with this situation.. It would be ever so GREATLY APPRECIATED!!! THank you, Shawn
