Can you help me with an issue? I have a Roland SP 300 and I am getting a seal issue with the magenta and the yellow. The yellow keeps getting magenta in it. I changed the damper, the cap top and it works for a bit and comes back. I had adjusted the cap height in the Service menu but I had it too high so the ink siphoned out. I had it at -.5mm. I chnaged it to 0 and the issue is back.
I did change the manifold back in Jan as the nipple broke removing the damper.
If I run a normal cleaning the test print prints good but then if I run an image it may print fine or it starts out orangy and then changes to yellow.
Currently i ordered oem damper and cap top as the other ones were aftermarket. I also ordered a new manifold in case I didn't seal it correct.
What would you suggest for the cap height or do you think I am doing the right thing.
Please advise any help you could give would be great as I am wasting tons of material, ink, money and time
