roland sp300-Temp to low
kustomkoncepts
turn off main power rocker switch and then on and then secondary power.
what does it do then?
I never got the low temp error before but I have got a (((heater voltage error)))
about 10 times in 4 years I just turn off and restart and works.
Tony McD
Same as Kustom here, I never got the low temp error before but I have got the heater voltage error. The shop was cold, and when I turned the office heat up it started like normal. It was like the cold room "freaked" the printer out.
CS-SignSupply
Error is there by design.
Operation Temperature: 15 to 32 degrees C (59 to 90 degrees F )
(20 degrees C [68 degrees F ] or more recommended),
Humidity: 35 to 80% (no condensation)
