Need Help Roland SP300v Error Code HELP
robert griffith
BIG BOB'S SIGNS & GRAPHIC'S
Roland SP300V Error Code Comes on when I true on the Printer CODE 0120 Just put in New Heads and Dampers Head Caps Head Cables all the good Things.
JBurton
Signtologist
Looks like an issue with the thermistor, here's info on it and a link to the document I pulled from.
  • Code: 0120
  • Description:Thermistor Error (Print Heater)
    Thermistor of the Print Heater doesn't work correctly.
  • Causes:Thermistor of the Print Heater is broken.
  • There is a cut-line/short in the wiring of the Thermistor.
  • Remedy:
  • 1) Check the wirings of Print Heater
  • 2) Thermistor Replacement
damonCA21
If you had just changed the heads I would look at replacing the cable to the black head, or swapping it with one of the others. The printer gets the head temp from the black one. I cant see any reason changing the heads would have damaged the platen thermistor. I was getting a temperature too low error once after a head change, and it was down to a bad black head cable.
Also try turning on in service mode, there is a thermistor check feature on the menu that will show if it is getting a signal
