roland sp300v issue
apex
the machines heads move and it even cuts but it does not print.
i was doing a cleaning i removed the heads and cleaned them and i put them back the machine no longer prints. I thought i might have blown the fuses on the main board but they are not blown so it has to be something else.
would a blown head carriage prevent the machine from printing?
im trying to pin point the faulty part so i can replace it. i am hoping its just not a new mobo that i need.
any insite on how this machine works and the electrical circuitry would be helpful
amw
Longtime Members
Before you did the cleaning was it printing?
Also you removed the printheads to clean?
Any reason why the needed to be removed?
Marsha
apex
Marsha
everything was workign fine, it just sat for a while and some nozzles clogged/dried up so i soaked and cleaned them
walker1
how do you know the fuses aren't blown if you don't have a clue about the circuitry... did you remove the heads from their mounting ? static discharge is a ***** this time of year...
hasie
Hi can sameone help me I got sp300v error 0040 scan motor
I replaced the linear strip because it where very old and miss cut and printed sametimes not good.Now I got this error code.I tried LINEAR ENCODER SETUP (Referential Time : 5min,4-5 LIMIT POSITION & CUT DOWN POSITION INITIALIZE (Referential Time : 10min.) cleaning and oil all but if I put mc on it starts up move to left and back to right then motor error
