Roland Truevis SG3 540
THRUTCHER
Signsbpl
Hello all. I have just purchased a new Roland Truevis SG3 540 and although everything is working well I have an issue. When the machine is printing I am getting various clicks, bumps and knocks coming from the belt and pulley area at the rear. Is this normal?
Has anyone else experienced this?
premiercolour
If you bought it new. Ask for repair. Do not attempt to fix yourself but warranty might gert voided. If you bought it used. Roland printer warranty is not transferable. Find a local technician to help.
Joe House
Sign Equipment Technician
The "chain" that carries the ink tube and cables clicks and clacks as it rolls back and forth - this is normal. This would be at the rear. The pulleys are at the ends of the printer and generally don't make noise unless the belt isn't adjusted properly.
If it's new, get with the dealer. If you bought it used, find a Roland tech to come check it out.
