Need Help Roland VeraCamm SP540v
Frankie Johnson
I have replaced the linear encoder, cap unit and print cables. You can see on the photo that it is jogging the bi-direct test strip and the test print. It was running fine when the black dropped. I’m out of ideas and no one near to help. Need some help please!
Technically, you need to go into service mode and run what is called linear encoder to see if it passes. Then you’ll know for sure if you have a problem or not.
JKstorm
I agree with that. If you know how to get into the service mode and know how to run the encoder test, it could be helpful. I had this same issue. I cleaned the strip according to Jim Hancocks instructions but I also did a cleaning of the sensor using compressed air. (not with a compressor but with a hand held can). I did this about six months ago and I have not had a single problem since. I did however order a new strip as a spare. They are getting hard to get, especially at a good price.
Reactions: 1 users
It looks like the bias adjustment is way off too. Basically, you're heads are crooked. I'd run all the head alignments especially if encoder fixes don't do the trick.
Frankie Johnson
It passed. I did that as soon as I replaced it. I'm guessing if the sensor is bad, it would not have read the encoder to pass it.
